Check engine light
Old Feb 10, 2008 | 11:54 AM
mpp31387's Avatar
Default Check engine light
Hey i have a 1994 3.4 camaro. The car has 194,000 miles but the motor has been rebuilt. It runs like a dream but when ever I let it down revv in 4th or 5th gear my SES light comes on. I have brought it to aamco but their scanner could not pick up any codes. I have changed out my O2 sesor, egr valve, plugs, wires and had a new cat put on but nothing has solved this problem. When it comes on i do not notice a loss in power. Thanks
Old Feb 13, 2008 | 01:39 PM
likearock91288's Avatar
Default RE: Check engine light
just throwing it out there...but i had a mustang that had an aftermarket cold air intake installed with a cone filter, and it had a small crack in the rubber connector piece that goes onto the pipe of the intake. that was causing my check engine light to come on...i guess irregular amounts of air coming in at different RPM's did it. if you have something like that set up on your car, you might want to check it out too.
Old Feb 13, 2008 | 02:12 PM
6v49der's Avatar
Stop "down revving" in 4th and 5th gear.
EagleRex
May 29, 2010 04:48 PM
ghanahost
Feb 21, 2010 12:49 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
gozzy341
May 20, 2007 11:00 AM
teamlilE1
Mar 12, 2006 02:22 AM
