changing a clutch
changing a clutch
ive got a 94 v6 camaro with a 5sp and tha clutch is going out. ive never had to replace a clutch in a camaro before and i was curious how hard this is goin to be. im not goin with a stock clutch. so if anyone has some advice for me it'd be much appreciated!!!!!!
RE: changing a clutch
Its basically the same as any rear drive front engine car. Remove the transmission & change the clutch.
May want to drop the exhaust to get more working room
Remove transmission & bellhousing as a unit.
Remove clutch slave cylinder and hang it so that it doesn't damage the hose.
Remove brace (metal rod)
Remove bottom cover
Separate bell housing from transmission
Unbolt & remove clutch pressure plate
Remov clutch disc.
Reverse procedure to install, but first align clutch disc to pilot bearing using alignment tool.
Torque pressure plate and cover bolts to 15 ft. lbs. plus 30°.
Check for proper clutch fork to clutch throwout bearing engagement
Remove bottom cover
Remov clutch disc.
since you have replaced clutches before you should not have a problem. I just had to change mine 95 5sp. The hardest part was getting that tranny back into the engine. I had to rock it back and forth. Oh and the top bolt on the flywheel housing by the drivers side was a pain to get off I had to get some Penetrating Oil for that one and a nice wable joint.
I just had to do this like 2 weeks ago.
Well Good look
Well Good look
DashingDaryl
05-21-2012 07:11 PM
Envisi0n91
03-03-2010 02:16 AM
