Changed the oil..
Changed the oil..
Would it hurt to overfill the oil about 1/2 a quart? I couldnt find the oil capacity in the book and i wasn't completely sure what it was, so i put in what i thought was a gallon, but after looking it was 5 quarts.. Then i found something that said the capacity was 4.5 quarts.. So, should i bother to drain 1/2 qt. oil?
RE: Changed the oil..
I did the same thing as you the last time I changed my oil. I ended up draining the ~1/2 quart out. If you have a good aim you can save the extra oil you added and use it. Just out of curiosity what type of oil and weight did you use?
