Car Trips over its self
Old Aug 11, 2008 | 10:34 PM
aaanflwr47's Avatar
Default Car Trips over its self
my car trips over itself when driving within the first mile of driving, then the service light kicks on, and the diagnostic says misfire in cylinder 4, what do i do?
Old Aug 11, 2008 | 10:41 PM
Fortee's Avatar
Default RE: Car Trips over its self
Fix the misfire.
Old Aug 11, 2008 | 10:43 PM
Guest
Guest
Posts: n/a
Tie its shoes!!
Ok seriously, because its specific to cylinder four, check the spark plug, wire... start with the basics. Report back and we'll go from there.
Old Aug 11, 2008 | 11:08 PM
aaanflwr47's Avatar
spark plug has been changed in cylinder 4 already, what now?
aaanflwr47's Avatar
spark plug in cylinder 4 has already been changed what now?
Old Aug 12, 2008 | 02:50 AM
evilkal's Avatar
I pick the ignition coil... NEXT!
Old Aug 12, 2008 | 10:44 AM
02StanGT's Avatar
Did you check the wire? Make sure it is snug on both ends, and that it is not burned anywhere.
Old Aug 12, 2008 | 02:41 PM
Guest
Guest
Posts: n/a
Do a compression test.
Old Aug 12, 2008 | 06:55 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
okay since i just went through just about all the steps fixing a misfire of my own....
1 plugs
2 wires
3 ignition coil
4 feul injectors
5. fuel filter
6. ignition modulator (thats what was causing mine)
7.compression test (lets hope you dont have to go here cus internal work aint cheap)
