Car overheats... Kind of
Old Sep 29, 2009 | 10:07 AM
have u changed the temp sensor?
Old Sep 30, 2009 | 07:47 AM
MissEvonne's Avatar
Well I definitely do not believe my fans are coming on. Gauge was pegged in the red on my way home yesterday and there was that "rut roh, something is burning" smell going on. The heat would NOT work, so I could do nothing to cool this car off. I had the coolant flushed twice--once when I bought it and once about late July (when they claimed there was no way it was actually flushed the first time). I'm going to take it in today, have them do a pressure test, check my sensors, fuses, yadda yadda. I sure hope this isn't a million dollar fix.
Old Oct 1, 2009 | 06:26 PM
justin_f_baby_96RS's Avatar
i having the same issue too, how do you bleed the cooling system?
Old Oct 1, 2009 | 09:39 PM
there are little brass screws that u lossen to let the air out of the system. one on the thermostat cover, one on the bottom of the tb and one inline by the alternator. there are a few threads on here about it. u will want to park the car on a hill with the front of the car up, helps alot to get the air to move. when the car is not up to operating temp open the radiator cap and fill with fluid 1/2 water 1/2 antifreez. open the bleed valves untill u have fluid coming out then close. the highest one by the alt may not allow fluid out untill latter. so then start the car and bleed again, this is when u should get fluid from the valve by the alt. refill the radiator close up and drive a few blocks down the road come back and bleed and refill once more.
Old Oct 2, 2009 | 08:00 AM
i have the 3.8 i thought there was only 1 bleeder on the tstat housing, but ill go check it out in a lil bit. would having an exhaust donut gasket bad, cause the car to go into limp mode because the o2 sensor isnt sensing enough o2?
JSGrind
Nov 6, 2011 10:53 PM
black89rs
Sep 25, 2010 09:46 PM
Cammy 3.8lV6
Feb 16, 2010 06:28 PM
Artist_X
Aug 17, 2009 11:18 PM
shinwolf14
Jul 15, 2009 05:05 PM
