can someone help me with t5 removal/install
Old Mar 5, 2011 | 08:07 PM
joseph_zlnsk's Avatar
Default can someone help me with t5 removal/install
I am capable of doing it. I have it removed. I just wanna make sure I don't miss anything putting it back in or any techniques for anything at all. I had a cracked bellhouse holding the slave cylinder. I got a new bellhousing now.
Old Mar 5, 2011 | 08:15 PM
BasicConcepts's Avatar
Technical User
theres no real tricks just make sure you dont put all the weight on the output shaft you could bend it
Old Mar 5, 2011 | 08:43 PM
Ok. I just wanted to make sure. Just so I don't miss anything. It's really be a b***h to have to pull it out to redo anything
Old Mar 5, 2011 | 10:23 PM
Did you replace the pilot bearing or the release bearing?
Old Mar 6, 2011 | 07:42 AM
I have not reinstalled yet. It started raining yesterday so I didn't have time to pull the clutch off. I know the engine as well as trans had been replaced before I owned this car. This car also used to be an automatic. I am going to inspect the clutch first to see if it needs to be replaced before I buy a new clutch kit. I dont think I can buy those bearings individually.
Old Mar 6, 2011 | 01:28 PM
Massey's Avatar
Yup you can
Pilot Bearing
http://www.oreillyauto.com/site/c/de...2325&ppt=C0015
Throw out Bearing
http://www.oreillyauto.com/site/c/de...1330&ppt=C0015
Happy hunting
Massey
Old Mar 11, 2011 | 10:08 PM
Schappie9's Avatar
while apart, get ur flywheel resurfaced.. its worth the $100 bucks or so and most new clutch warrenty will not be effective if not done
MoonDoggy
Dec 10, 2014 07:36 PM
NSXTASY
Jun 9, 2012 09:17 PM
adamcc91
Aug 14, 2009 10:32 PM
cn_bailey32807
Dec 31, 2008 02:42 PM
tspence45
Feb 7, 2008 05:51 PM
