Can an intake gasket failure cause the cooling system to build pressure?
Old Apr 9, 2010 | 05:57 PM
I will have to look for the info but there is some sweet solid copper headgaskets for these now and if you got couple of extra bucks you can upgrade the rockers for a few extra ponies.
Old May 6, 2010 | 02:35 PM
JC316's Avatar
Oh and just in case anyone is wondering on this thread, I found the issue. Two badly warped heads.
Old May 6, 2010 | 06:00 PM
Fixable? or did you need to replace them?
Old May 6, 2010 | 08:10 PM
Massey's Avatar
This is a head gasket or cracked head issue all the way. I was guessing this well before I seen the results of the #4. The engine was pushing compression pressure into the water jacket but not sucking any antifreeze back into the cylinder. My X had a tempo do this to us and it turned out to be a cracked head. These 3.8L engines are not known to blow head gaskets or crack heads so I would defidently check things over when you have it apart. The 3.8 heads can be removed without removing the engine but dropping the engine out the bottom of the car would make this job alot easier.
Massey
Old May 6, 2010 | 08:44 PM
Since he knows the heads are warped I think he already has them off. Head gaskets are very common on the 3.8. In fact that and intakes are the only common engine repair I can think of. One warped head is not common on these cars unless it has overheaded real bad. 2 warped heads is an indication that something went real wrong.
Old May 6, 2010 | 09:19 PM
JC316's Avatar
It was a pain to do it in car, but I did it. Had the heads checked for cracks and resurfaced. I know exactly what happened to this car, the evidence is clear. The intake gasket started leaking and they put stop leak in and continued to drive. The intake gasket was completely destroyed.
Old May 6, 2010 | 11:43 PM
Massey's Avatar
This site or my computer is messing with my head... When I made my post there was not 2 pages but after I posted the thread showed the second page with the answers. This is not the only thread here to do this to me. Grrrr
I also cant view the pics of others rides
Massey
Pig Hunter
Jan 31, 2012 03:09 PM
99 camaro T-Top
Oct 6, 2010 09:51 PM
90iroc-z28
Apr 28, 2009 04:57 PM
dcanada53
Mar 5, 2008 06:01 PM
bconz350
Jan 4, 2007 10:30 AM
