A/C water in passenger-side floorboard
Old Oct 14, 2009 | 12:03 AM
dublinos's Avatar
Thanks all, I will have a look this morning under the car.
Old Oct 14, 2009 | 11:53 AM
dublinos's Avatar
Got it fix the drain box was blocked. I've got a nice shower under the car.
For your info the drain box is near the exhaus under the car.
Thanks all of you for your help.
Old Oct 16, 2009 | 11:40 PM
305pride's Avatar
that happened to my car along time ago too. i guess it was blocked some where from dirt and stuff but it must have unpluged it self from the dirt cos it doesnt do that anymore.
Old Nov 20, 2009 | 11:52 AM
95V6-$600's Avatar
Default It is very possibly the A/C
When I bought this car used the heater core was bypassed and I could see from underneath that there was obviously a leak into the passenger compartment.(Rust) Naturally I put 2 and 2 together, replaced the core, put it all back together and it started leaking again, but only when the a/c was on. There is a seam in the bottom of the drip pan that is leaking condensation into the passenger compartment that I can only assume was originally caused by the leaky heater core.
Its a real &^%$# to get to but I think I can pour in some epoxy to stop the leak.
Old Nov 20, 2009 | 02:16 PM
libertyforall1776's Avatar
Be sure you check all your rubber seals for leaks, especially if you have T-Tops...
Old Nov 20, 2009 | 04:32 PM
Go back and read this thread from the beginning, and what the fix was. Your A/C condensation isn't draining, meaning.....a clogged drain hole. Epoxying something isn't going to stop the water build up, it needs to get out.
AmericanMuscle1989
Oct 17, 2013 07:51 PM
DMateo
Mar 20, 2009 11:51 PM
tirocz
82-92 V8 Tech
Mar 25, 2008 05:38 AM
Andrew*B
Oct 11, 2007 11:54 AM
digital_punk02
LS Series Tech
Jun 3, 2007 08:02 PM
