A/C question
Old Jun 13, 2008 | 07:33 PM
JaySan's Avatar
Default A/C question
ok so I my compressor went bad and i took it out and installed a new one. I was told that I need to evacuate my system , but my question is what if I just recharge it and dont evacuate my system ? What would happen ?
Old Jun 13, 2008 | 07:41 PM
blackz87's Avatar
Default RE: A/C question
You might loss the new compressor.
Old Jun 13, 2008 | 09:32 PM
When you open an AC system the refrigerant goes out and is replaced with humid air. The air does not help the AC but takes the place of some refrigerant, and the moisture tends to freeze inside the system,preventing it from working properly. For proper operation, all the air needs and moisture needs to be evacuated, and the receiver drier replaced. Also make sure the system is recharged with the proper type and quantityof refrigerant.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
