A/C not working - not sure why
Old 05-12-2013, 10:40 PM
2000CamaroV6's Avatar
Default A/C not working - not sure why
Currently my A/C is not working and I'm trying to figure out why. I just got my Camaro a few weeks ago, so I don't know the history. I do know that when I turn on the A/C the compressor doesn't kick on. The belt spins, but not the compressor. So, I looked in the manual and it seemed to indicate #6 and #16 on the fuse panel control the HVAC. I checked both fuses and they're fine. What else can I check myself before I have to take it to a shop to be diagnosed?
When it comes to A/C, my knowledge is limited, so please don't assume I've checked certain obvious things because I probably haven't
Thanks.
Old 05-12-2013, 11:57 PM
fbodyrs96's Avatar
if its low or out of r134 it wont engage, an that also means you have a leak somewhere.
Old 05-13-2013, 08:35 PM
Default What I learned...
I hooked up pins 30 and 87 for the "A/C COMP" relay and the compressor fired right up. So, I know the compressor works now, YEA!!
A friend said I should now try:
1. Jump the high side switch -- if compressor comes on, it's a bad high side switch. Otherwise go to step 2.
2. Jump the low side switch -- if compressor comes on, either switch or low freon. Otherwise go to step 3.
3. Bad switch on the dash.
The trick is that I have no idea where those switches are. I've tried following the lines from the compressor and the accumulator, but I don't see any switches. Can anyone provide a diagram? Or does a 2000 Camaro work differently somehow?
Old 05-14-2013, 12:06 AM
fbodyrs96's Avatar
There's only low side switch and it's the senors that plugs in right before going into the firewall.
justin1989
82-92 V8 Tech
11-04-2007 01:12 AM
camaro girl
05-30-2007 01:19 PM
MarkyMark
01-29-2007 01:01 AM
Quick Reply: A/C not working - not sure why
