A/C Clutch Bearing Replacement
Old Dec 11, 2006 | 12:26 PM
gdrnec's Avatar
Default A/C Clutch Bearing Replacement
Hello,
This is my first post to this group so hello everyone and I hope there is an expert out there that can help.
I am trying to replace the A/C clutch bearing on a '94 Camaro 3.4L and I have run into a problem.
There is a retainer of some sort (looks like a tab washer) holding the clutch plate cover to the compressor assembly. I can't seem to remove said retainer. Does anyone know if there is a special tool for this or a trick that they know of? I tried going to the local Chevy dealer to eyeball the part but that retainer type was not in the part assembly.
I hope someone out there has done this job and can offer advice.
Thanks in advance.
Geoff
Old Dec 11, 2006 | 01:03 PM
Default RE: A/C Clutch Bearing Replacement
You need special tools to do work on the AC compressor. Best thing IMO is to let arebuilder handle it. By the way, you posted in the wrong section, the 3.4 is not a LT1, so the post was moved.
Old Dec 11, 2006 | 04:48 PM
MadMikeZ28's Avatar
ORIGINAL: z28pete
He can dream, cant he
He can also dream about owning a puller, installer and a holding tool. Plus adjusting the clutch to the right gap.
Old Jun 1, 2008 | 12:41 AM
whatsupdoc's Avatar
All these tools can be loaned out from AutoZone. Just measure the clearance before removing the clutch and ensure it's the same when reassembling.
v6baser
Sep 28, 2013 10:04 PM
3800camaro
Dec 7, 2011 06:19 PM
thor9812
Aug 23, 2010 05:47 PM
Rob79
Mar 17, 2010 08:05 PM
jbassiii
Oct 2, 2006 04:55 PM
