brakelight out, bulb replace doesn't fix
Old Oct 12, 2008 | 02:26 PM
marklar's Avatar
Default brakelight out, bulb replace doesn't fix
My gf's 2002 V6 driver's side brake light isn't working. Replacing the bulb doesn't fix it... other brake lights come on so it shouldn't be the fuse. Here's what I've looked at.
-Checked voltage between electrodes in the socket with brake lights on, zero volts. Made me suspect a bad socket.
-Stripped off a bit of wire behind the socket and measured voltage, still no voltage.
-With car off, measured resistance between electrodes, which was ~0 Ohm, so they're shorted somewhere. I don't know what the upstream electronics look like, maybe they're supposed to be shorted when the car is off.
Has anyone seen this before? Any suggestions? The old bulb is burned out, to the point where the whole thing is black.
Thanks for the help.
Old Oct 12, 2008 | 09:03 PM
sledhed32's Avatar
Default RE: brakelight out, bulb replace doesn't fix
should have individual fuses. I think.
Old Oct 13, 2008 | 11:05 AM
RSSteve's Avatar
i wouldn't think they would have individual fuses... I have never seen that before.
redrooster888
Mar 11, 2011 09:36 PM
chrosbor
May 17, 2009 11:35 AM
Stas
Aug 11, 2007 08:03 PM
AFilip
Apr 23, 2007 04:18 PM
Kardon507
Mar 2, 2007 12:38 AM
