brake light won't disappear! 94 3.4L
Old Jan 20, 2012 | 11:17 AM
richard.nelson100's Avatar
Default brake light won't disappear! 94 3.4L
Guys I've just replaced both brake switches at the pedal and inspected the parking brake switch. The entire brake system is new except for the abs module. I took the rear end off and had it rebuilt. I put a new traction control sensor on the differential and I also replaced the front bearings (comes with new sensors). I've checked everything and I still have a brake light. Is it the brake pressure sensor on the left side of the abs module? By the way....no abs light.
Old Jan 20, 2012 | 11:24 AM
You probably still have air trapped in the system, and that will turn on your brake light.
Old Jan 20, 2012 | 11:30 AM
I'm going out right now to bleed the system.....I'll let you guys know.
Old Jan 20, 2012 | 07:22 PM
After putting the car up on jack stands, I had someone press the brake while I checked the calipers. Even though less than a year old.....guess what.....the A1Cardone remans were faulty. I took them in and swapped them under warranty. After a nice bleed.......NO MORE BRAKE LIGHT!
Socom
Nov 9, 2013 01:41 PM
Luz Hernandez
Nov 11, 2010 01:48 PM
hpd218
Aug 24, 2010 12:05 PM
Skiwee10
Aug 31, 2006 12:54 AM
