Brake Light
Old Aug 27, 2007 | 12:41 AM
94Red's Avatar
Default Brake Light
OK so heres the story, the other day my car took a crap and didnt wanna start, after trying a few times pumping the pedal 3-4 times, i realized there was no gas smell, long story short, no fuel , problem was i had to get it off my hill, so i put it in ACC and rolled it down the hil with no power, now my brake light is on, car moves no problem, could my emergency brake be stuck a little??? , btw replaced the fuel pump myself, by cutting a hole in my trunk !!!! lol it was an experience but im happy i did it myself , plus now i got a cool hidden door in my car lol.
Old Aug 27, 2007 | 07:15 AM
usarmyrangrs's Avatar
Default RE: Brake Light
Well, on fuel injected cars, pumping the pedal will not give you any more fuel than desired. The injectors are controlled by the PCM and are directly controlled by it until the engine is running.
Old Aug 27, 2007 | 03:21 PM
bluovlh8er's Avatar
yea, peanut... you thought ur car was carbed???
Old Aug 27, 2007 | 11:53 PM
94Red's Avatar
Lol noooooo peanut??!? lol i didnt wanna flood it but i gues i cant, but anyway......... whats the deal with the brake light??? i mean that lights on, and the ABS INOP light is on also.
Old Aug 28, 2007 | 03:27 PM
ranger4620's Avatar
my abs inop light came on about 2 days before the whole abs systme quit qorking. i had to replace the abs module. does it act up at all when you stop?
Old Aug 28, 2007 | 10:25 PM
The red brake light sees a fault in the brake system itself. Perhaps a small leak, or some uneven pressure at a certain point. Perhaps a faulty switch, too. As far as the ABS light, only an ABS scanner or scan tool can really narrow the problem down. It could be anything from the valve body to a faulty wheel speed sensor.
Old Aug 29, 2007 | 12:05 AM
Chappie99's Avatar
You may have messed up the speed sensor while moving backwards.
Old Aug 29, 2007 | 12:15 AM
94Red's Avatar
Hmmm All very good ideas, thanks guys......Im gonna scan it later today and see whats wrong, i know theres no leak i put it up on the lift again today and cleaned off all the **** outta the bottom of the car and saw no brake leakage lol. thanks again
Socom
Nov 9, 2013 01:41 PM
hpd218
Aug 24, 2010 12:05 PM
MegzZ28
Nov 27, 2007 01:47 PM
Skiwee10
Aug 31, 2006 12:54 AM
The_Shadow
Dec 2, 2005 07:59 PM
