Brain buster for you electrical guru's!
Old Jul 17, 2007 | 11:32 PM
3.8 V6's Avatar
Default Brain buster for you electrical guru's!
I use the Alldata wiring diagrams for my automotive repair work because I find that they are the closest I can get, to what the GM Factory Service Department uses. I need clarification on the wiring diagram for a 98 Camaro 3.8 V-6 engine. The Alldata wiring diagram for theignition control module shows terminal (F) running to cavity pin 7 of the C1 circuit of the PCM. The diagram for the iac valve also shows terminal (D) of theiac valve running to cavity pin 7 of the C1 circuit of the PCM. This is impossible. They both can't operate fromcavity pin 7 of the C1 circuit. Can someone explain what is happening here? Or do you have a wiring diagram showing something different? Thank you, Tommy.
Old Jul 18, 2007 | 01:34 PM
libertyforall1776's Avatar
Default RE: Brain buster for you electrical guru's!
Ya should post a pic of what you describe...
Old Jul 18, 2007 | 02:13 PM
3.8 V6's Avatar
How do you go about posting diagrams or pictures?
Old Jul 19, 2007 | 01:02 AM
3.8 V6's Avatar
I tried following the diagram I got from the GM Dealership. No Good! I could not even pick up iac voltages with that wiring configuration. I ended up using the 98 Grand Prix 3.8 V-6 wiring diagram. With the 98 Grand Prix diagram here's the voltages I'm getting at the iac valve with the engine running:
Terminal (A) 0.88 volts (Lt green/black wire)
Terminal (B) 12.44 Volts (Lt green/white wire)
Terninal (C) 0.88 volts (Lt blue/black wire)
Terminal (D) 12.43 volts (Lt blue/white wire)
There is one problem remaining, which has been my problem all along. The iac valve is getting hot. After the engine has been running for about 5 minutes, the iac valve gets very hot. I'm able to touch it, however, I'm only able to hold on to it for a few seconds then I have to remove my fingers or I'll get a burn. I must admit that with this wiring configuration, the engine runs much better. Not perfect, but better. I just need to find out what is causing the iac valve to get that hot. Has anyone experienced this problem before? Any suggestions? Thank you, Tommy.
oldman9
May 5, 2013 04:30 PM
HAULINanBALLIN
Jun 14, 2007 10:25 PM
DFENS
Sep 13, 2006 09:30 PM
ScottD
Sep 1, 2006 01:40 AM
thadd154
May 15, 2006 12:57 PM
