Boost retard/Ignition Box for Supercharged 3800
Old Jul 9, 2010 | 01:58 PM
midwestdave33's Avatar
Default Boost retard/Ignition Box for Supercharged 3800
Who makes a Ignition box with boost retard and or: a stand alone boost retard compatable with the OEM 3 coil type ignition on 96 3800 camaros? I've talked to summit and they had notta according to one of their tech lines.
This is my plans and build thread for my car if you have any questions. https://camaroforums.com/forum/93-02-v6-tech-14/build-thread-powerdyne-supercharged-3800-96-camaro-53096/
Old Jul 9, 2010 | 03:04 PM
Have you tried the MSD catalog? http://www.msdignition.com/product.a...s=boost+retard
IMO The most elegant solution is to do away with the MAF, replace the MAP with one designed for a supercharged engine, and reprogram the PCM for speed density and the proper ignition timing and fuel delivery.
Old Jul 9, 2010 | 05:29 PM
Yeah, i have found several units like that. I was really hopeing to get away without completely changing the ignition and air/fuel managment system (budget and all...).
1. What you're describing seems like alot of work. Can you get more detailed about what all is involved? Is it something you've done before?
2. Is the boost retard something i can have my tuner just set to a certian setting when he is tuning it? I realize i would loose some adjustment for quality of gas and such. But i really don't spend much time at the track. Its mainly a street car/driver. LOL, I ran it in bone stock form just for fun and it ran 16.3's meh... this should improve that quite a bit...
3.Iwas really thinking about upgrading to some high output coils and wires and running one of these. http://www.jegs.com/i/Vortech/933/5A001-001/10002/-1 (not sure why Jeg's don't have a pic up but its designed to be run with a centrifugal setup even if it is a different brand...)
Thoughts?
Old Jul 9, 2010 | 05:54 PM
libertyforall1776's Avatar
I think you might want to contact a shop that specializes in 3800 performance...
Perhaps:
http://www.intense-racing.com/
http://www.3800performance.com/
Old Jul 9, 2010 | 06:11 PM
Perhaps:
Good idea. Just did.
midwestdave33
Jul 11, 2010 05:06 PM
pimpdd101
Jun 23, 2008 12:28 PM
coprunr
VS
16
Mar 11, 2007 08:33 PM
69camarokid
Mar 8, 2007 12:09 AM
Crash83
May 21, 2006 02:23 PM
