Better Gas Mileage 3.4
Old Jun 20, 2010 | 01:24 PM
Chaotic94's Avatar
September 2011 ROTM
Default Better Gas Mileage 3.4
How can I get better gas mileage on my 1994 5-speed. Right now I'm getting 17mpg. It was getting 14mpg before I put injector cleaner in my fuel... Ideas?
Old Jun 20, 2010 | 01:32 PM
off the top of my head,,, check fuel pressure, check for leakage at the fuel pressure regulator, replace 02 sensors, new spark plugs, test evap system, test egr, test and clean maf, test map, scann for trouble codes, test/check knock sensor, check brakes for excessive drag.
Old Jun 20, 2010 | 01:35 PM
Chaotic94's Avatar
September 2011 ROTM
Would exhaust do anything? My cat is bad and needs replaced. When I do that I'll have a Z28 dual outlet exhaust installed. Also I'm going to replace the air filter. Will this do me any good?
Old Jun 20, 2010 | 01:58 PM
absolutely. forgot to list a plugged cat.
Old Jun 20, 2010 | 02:54 PM
Chaotic94's Avatar
September 2011 ROTM
Any idea what a new air filter, cat, and dual outlet z28 muffler will bump my mpg's up to?
Old Jun 20, 2010 | 03:06 PM
air filter and exhaust will add power but do little to mpg. a tune at a dyno shop or a place like pcmforless will add power and mpg. fit and performance wize k&n, moroso and slp make the cai setups that work best on these cars. plugged cat can ruin the 02 sensors and plugs as well as screw mpg
Old Jun 20, 2010 | 03:22 PM
Step one is getting the car back close to where the it was when it was new. If your problem is an O2 sensors then it will not matter what you do to the car until the O2 sensor is replaced. I am just using the O2 sensor as an example but get everything working right then look to a nice CAI and Duel exhaust and a tune. Sounds like your cat should be the first thing you address.
Old Jun 20, 2010 | 03:25 PM
Chaotic94's Avatar
September 2011 ROTM
Well I wouldn't call mine a plugged or clogged cat. It's just rattling like crazy. I can still run my rpm's up to 6000. I was told if the cat was clogged/plugged that I would be lucky to get 3000rpm... And btw, there are no dyno shops around where I live. Or so I don't think so. How much would it cost to do a tune at a dyno shop?
Old Jun 20, 2010 | 03:27 PM
Chaotic94's Avatar
September 2011 ROTM
I'm doing a dual outlet exhaust and a new magnaflow cat new week. So maybe that will help. I haven't looked at CAI's yet but plan on it in the near future. Everything on the car is working fine. I just got new spark plugs and I'm getting plug wires soon as well. I had planned on an air filter but I just looked at it and it looks brand new.
Old Jun 20, 2010 | 03:30 PM
if thats the case have it scanned for codes and/or pick up a aldl cable and a program so you can see for yourself whats going on.
