Best way to remove condensation from a light lens
Old Feb 28, 2011 | 09:54 AM
Chevy101's Avatar
Default Best way to remove condensation from a light lens
I have condensation forming on the inside of my pass signal housing what's the best way to remove the water?
Old Feb 28, 2011 | 10:31 AM
your lens is leaking so drying it will be futile. could try pulling the lense housing and bring it inside and dry. once dry find any leak in the housing seal and repair.
Old Feb 28, 2011 | 10:44 AM
Massey's Avatar
^^ +1
These like to leak around the seam where the grey and amber plastic meet. Use some medium thickness CA glue and accelerant to seal it up. If the amber is cracked get a new light, and also check the seal on the socket, that is another place water gets in.
Massey
Old Feb 28, 2011 | 11:30 AM
Chevy101's Avatar
Is it easier to remove it from the bottom or should I remove the head light and take it out from there?
Old Feb 28, 2011 | 01:29 PM
Massey's Avatar
Personally I like to get them out from the top by removing the headlight. And I also pull the front cover off the header at the middle to make removing the headlight easier as well.
Massey
Old Feb 28, 2011 | 01:33 PM
Chevy101's Avatar
What cover are you talking about?
Old Feb 28, 2011 | 01:57 PM
Massey's Avatar
The bumper cover. There are 5 plastic push rivits where the header holds the bumper cover. Remove these rivits and then pull the bumper cover over the header and you will have an easy day removing the headlights.
Massey
Old Mar 4, 2011 | 07:22 AM
Chevy101's Avatar
I removed the signal lens and I am letting it dry now. Turns out I am missing the gasket around tge signal socket. I am going to glue it up just to be safe. Thanks Massey it was so much easier from the top
TimT*02
Aug 18, 2012 10:20 AM
Vetteman61
Feb 28, 2011 04:38 PM
M.$tErNeR
LS Series Tech
Mar 18, 2007 07:50 PM
97camarogrl123
Aug 30, 2006 02:23 AM
wbwiley
Mar 28, 2006 05:10 PM
