Best way to find replacement engine on the cheap?
Old 03-20-2008 | 06:31 PM
raymose's Avatar
Default Best way to find replacement engine on the cheap?
I seem to have blown a rod (1996 camaro 3.8 3800 series II engine) since theres a loud knocking noise when i rev it up. Im wondering, what would be the best way to look up a replacement engine online since everytime i look up a 3800 series II engine it shows all the 3800 front wheel drive engines that are different than mine. I called a junkyard and they have a 3.8 v6 from a 1997 firebird with 90k for 400 dollars. will it fit and is this a good deal? thanks.
EDIT: typo my bad it is a 3.8 thanks for the correction!
Old 03-20-2008 | 06:41 PM
02StanGT's Avatar
Default RE: Best way to find replacement engine on the cheap?
It should be a 3.8, not 3.6. That's not bad. You can check here also... ---> http://www.tacreationsusa.com/v61.htm
Old 03-20-2008 | 07:11 PM
Some of the larger salvage yards will even install and warranty the engine.
Spelljunkie
11-26-2014 02:29 PM
butterfly22085
10-01-2009 11:22 AM
gmman200
07-02-2008 07:05 PM
jesses
08-09-2007 12:00 AM
