biggest engine
Old Mar 15, 2008 | 09:10 PM
jdelag's Avatar
Default biggest engine
whats the biggest i can fit in my 2000 v6 camaro ? and what would be the biggest engine with slight mods.?
Old Mar 15, 2008 | 09:46 PM
Chappie99's Avatar
Default RE: biggest engine
biggest V6 or biggest engine anything? It all depends on how deep your pockets are. With $$$$ you can make anything work. There is a dude who stuck a 1100 CID tank engine in his mustang. Will this be a racer or daily driver? You need to take into consideration what you are trying to do and to what extent you will go.
Old Mar 16, 2008 | 07:51 PM
jdelag's Avatar
Like without doing much side like buying new transmission and stuff like what could be the biggest engine I can install besides my 3.8 like I want to make my car a racing car.
Old Mar 16, 2008 | 07:52 PM
jdelag's Avatar
And yeah like biggest engine.
Old Mar 16, 2008 | 07:53 PM
02StanGT's Avatar
ORIGINAL: Chappie99
He speaks the truth.
Old Mar 17, 2008 | 06:57 PM
jdelag's Avatar
I know that with money you can make anything work but let's say I wanted to put a 301 engine would that work in my car which has a 3. 8 engine right now
Old Mar 17, 2008 | 07:16 PM
02StanGT's Avatar
I guess I'm unfamiliar with the 301. I just looked it up, and I don't see why it wouldn't fit. Hood/cowl clearancemay be an issue though.
Edit: As I'm sure you know, this will not be a direct swap.
Old Mar 18, 2008 | 01:55 PM
Labyrinth9's Avatar
i know a guy who put a 350 with 465hp in his
Old Mar 18, 2008 | 06:16 PM
This is about as big an engine that can be put in a car. This shows how to stick a 3000 HP Rolls Royce Merlin V12 in a 55 Chevy, but you can use the same procedure with some mods to put the Merlin in a Camaro. LOL
http://www.rodshop.com.au/project55.htm
Road test:
http://www.youtube.com/watch?v=SIj2GVfua84
Old Mar 19, 2008 | 06:55 PM
jdelag's Avatar
Then if its not a direct swap what would I have to change like I think my transmission can handle the 301 but I'm not sure about the 350 but if I wanted to put the 350 what would I have to change and what would I have to change for the 301
