Belt Squeek
Old Jan 14, 2007 | 07:42 PM
Rs Camaro Kid's Avatar
Default Belt Squeek
My belt squeaks on my 3.lL and i dont know what the prob is.. it could be the tensioner but where is that located on the 3.1?
THX
Old Jan 15, 2007 | 10:03 PM
sooperdewd's Avatar
Default RE: Belt Squeek
have you replaced it? because on every car I have ever owned or knowned when they belts squeek you replace em because they are slipping. I dont know if this is your problem but you didnt say anything about when it does it or if it changes sound wise and so on.
Old Jan 16, 2007 | 12:28 AM
01 Camaro Cp's Avatar
Belt squeaks with these serpentine belts are common once the belt gets old and hard (read that as "prone to fail soon"). But they'll also squeak if one of the pullys are out of alignment. Make sure the idler and tensioner pully bearings aren't the cause of your squeak and if you're too cheap to replace the belt, a little talcum powder (not corn starch) on the inside of the belt will stop the squeak for a bit.
Old Jan 16, 2007 | 01:08 AM
it isnt constant it only sqeaks every second or two
Old Jan 16, 2007 | 01:16 AM
oh ya and the belt is basically brand new it was put on about 4 months ago
Old Jan 16, 2007 | 01:21 AM
I'd check the bearing in the big idler pully. Pop off the belt, remove the pully and press against the center of the bearing as you turn it. Do this for both sides of the bearing. You don't want to feel any grinding, tight spots, roughnessor excessive loosness in the bearing. They're a common failure item, modestly priced and in stock at most parts stores.
Old Jan 16, 2007 | 01:25 AM
I know this is kind of a dumb Question but which 1 is the idler?
Im only just turning 16 in a week so i dont know a lot about this stuff, only the basics
Old Jan 17, 2007 | 01:42 AM
Your local library probably has some good books with nice pictures that should be able to help you learn some of these basics. I don't want to confuse you by saying something like "It's the 5" (or so) round thing on the left (passenger) front side of the engine with a single 13mm hex head bolt holding it in place. Oh by the way the belt is in contact with it so if you got lost you could just follow the belt around until you found a pully that's not connected to anything like the water pump, power steering, alternator,crankshaft or auto tensioner."
Mrjshua
Jul 30, 2011 03:38 AM
JordanN
Dec 4, 2010 05:39 AM
baseballer91
Apr 11, 2008 11:23 PM
purpl96
May 23, 2007 08:55 PM
carguylt1
Oct 29, 2006 12:25 PM
