Bad Oil Leak
I got the shield off the tranny, and it had oil in it also, With out having a light with me under the car tonight, I could not tell to much, but it would have to be coming from the back of the motor is the shield had oil in it, don't you think.
I would also check the plug where the distributor would go, I know that the old 3.1's had this problem where the gasket would go bad and lose a lot of oil. Also that might explain why its leaking on both sides cause it is placed in the middle of the top of the block
#20
That's not a leak, that's a gusher! With the car up on ramps and engine running, you should be able to get under there and see where it's flowing from. Be sure to wear your raincoat!
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
