Another day, another issue (power steering)
Old Nov 6, 2009 | 09:39 AM
dkn920's Avatar
Default Another day, another issue (power steering)
Hello guys! Its been a good week or so since I have been here.
So, straight to the point, 2001 V6 auto with 152k is leaking power steering fluid like no bodies business. I first changed the pre-bent hose that goes from the reservior to the PS rack I believe. There was a build up of gunk do to a leak. But now, the leak has gotten worse to were the camaro is parked, leaks on the passenger side. BUT I think it travels toward that direction because the driveway is slightly slanted.
Any suggestion or experience on what, where or how I can fix this issue?
Anyone know an awesome mechanic with great prices out in CA, riverside area? LOL...Getting tired of fixing this thing!
Sidenote:
Need to get a pressure checker due to slight loss of coolant.
Need to change out the shocks.
Bulbs need to be changed.
Old Nov 6, 2009 | 12:40 PM
evilkal's Avatar
My return line has a leak in it and i'm too lazy to fix it if that helps
Old Nov 6, 2009 | 09:17 PM
dkn920's Avatar
Haha, just a little. I think I have new return line as well. I thought I might have to get a new power steering rack? Am I over thinking stuff right now?
Old Nov 6, 2009 | 09:22 PM
machine1999z28's Avatar
^^^ May be your rack. Mine leaks from the drivers side end seal (the one under the rubber boot). Just don't let it run out of fluid or you'll be replacing the pump too
Old Nov 25, 2009 | 11:25 PM
dkn920's Avatar
Forgot about this one thread.... Still having the issue. The leak seams to flow from driver side to pass. side. My driveway is uneven so I know thats why the leak flows in that direction. There is a large area of gunk covered parts but still unable to figure out what.
Does anyone have smart ways to narrow down the leak>? Thanks guys!
Old Nov 26, 2009 | 12:22 PM
libertyforall1776's Avatar
Clean everything -- it will then be easy to see where the leak is coming from. In general it's always easier to see things when they're clean. ;-)
This should help:
Document ID# 659606
2002 Chevrolet Camaro
Power Steering Fluid Leaks
Step
Action
Yes
No
Did you review the Power Steering System General Description and perform the necessary inspections?
Go to Step 2
Go to Symptoms - Power Steering System
Verify that power steering fluid leaks are present.
Is the power steering system leaking?
Go to Step 3
System OK
Inspect the power steering system fittings.
Are the fittings leaking?
Go to Step 7
Go to Step 4
Inspect the power steering hoses.
Are the hoses leaking?
Go to Step 8
Go to Step 5
Inspect the power steering pump and the reservoir for leaks.
Is the power steering pump or reservoir leaking?
Go to Step 9
Go to Step 6
Inspect the power steering gear for leaks.
Is the power steering gear leaking?
Go to Step 10
Go to Step 11
Tighten the fittings. Refer to Fastener Tightening Specifications .
Did you complete the repair?
Go to Step 11
Replace the power steering hoses. Refer to the appropriate procedure(s):
Power Steering Reservoir Outlet Pipe/Hose Replacement
Power Steering Pressure Hose Replacement
Power Steering Return Hose Replacement
Go to Step 11
Replace the power steering pump or reservoir. Refer to Power Steering Pump Replacement or Remote Power Steering Fluid Reservoir Replacement .
Go to Step 11
10
Replace the power steering gear. Refer to Power Steering Gear Replacement .
Go to Step 11
11
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Old Nov 27, 2009 | 06:45 PM
Toneman07's Avatar
steam clean the under side of motor isolate leake and fix... high pressure hose is common issue for the leak if thats what u just replaced make sure its on correctly
Gubert
LS Series Tech
May 1, 2011 04:31 PM
TheGrizz
Mar 5, 2011 10:37 PM
301Breed
Feb 21, 2011 11:00 AM
g3mini609
Mar 1, 2010 05:12 PM
jds88z28
Oct 1, 2007 10:02 PM
