Amp Wire Install
Old Nov 8, 2009 | 04:21 PM
Gmed1990's Avatar
Default Amp Wire Install
Some what of a walk through for running an amp wire
Locate the computer on the passenger side
Remove the 2 bolts holding in down and pull it out of the way. You do not have to disconnect the computer from anything.
The firewall gromet is very easy to access now. Just poke a hole a pull your wire through.
On the underside of the dash on the passenger side remove the 2 clips and pull off the panel.
Look for amp wire up in the corner under your dash and pull it through. I use a silver 4 gauge wire.
Melissa Flournoy
May 1, 2012 07:11 AM
NorthernCrew454
Aug 20, 2011 07:14 PM
9434V6
Aug 19, 2011 08:52 AM
hshawn31
Jan 13, 2008 02:45 AM
twankieman91
Dec 19, 2007 06:46 AM
