alternator
Old Feb 3, 2010 | 03:13 PM
chrisgray86's Avatar
Default alternator
Hey guys I think my alternator is going bad it is making some whistiling noise and the belt is tight so I am going to replace it ITs a 2002 V6 Camaro. Is there any threads that help with how to do an alternator change? I guess i could pick up one of those books but i thought i would ask. It really does not seem like it would be too hard to do.
Old Feb 3, 2010 | 05:47 PM
Pretty straight forward. Remove belt, disconnect wires, unbolt alternator.
Old Feb 3, 2010 | 06:09 PM
Now THAT one needs to be stickied. I did write it down for future reference, but I'll probably lose the note!
Old Feb 3, 2010 | 08:30 PM
osduck5's Avatar
You can remove one of the battery cables with the engine running and if the alt charging is bad, the engine will die. If it is a bearing going on the alt, it will continue to make the noise. Also, I have seen some alt's make that noise if someone is running alot of electronics and draining the battery.
Old Feb 3, 2010 | 08:31 PM
Should make a video clip and post it. lol
Old Feb 3, 2010 | 08:39 PM
osduck5's Avatar
that not nice!
Old Feb 3, 2010 | 09:20 PM
libertyforall1776's Avatar
Don't forget to check your Alternator Fluid...
WIspartan1026
Jun 7, 2011 04:36 PM
94z28chevy
Jul 20, 2009 03:37 PM
lovelacci
Aug 14, 2007 12:39 AM
joeyninetoes
May 18, 2007 03:33 PM
92ChevCam305
Dec 26, 2004 03:50 PM
