ABS inop ??
Old 05-08-2009 | 01:07 PM
1999chevy's Avatar
Angry ABS inop ??
the abs inop light in the lower left hand corner in the dash how do i get it off its been bugging the hell out of me !!!! lol help me with that i dont even know where to start
Old 05-08-2009 | 02:43 PM
02StanGT's Avatar
How about your 3rd brake light, does it work when you apply the brakes?
Old 05-08-2009 | 06:48 PM
dletner's Avatar
mine came on and i bled my brakes and it fixed it
Old 05-08-2009 | 06:53 PM
niteman's Avatar
mine came on when I went thru a big puddle of water... was on for 3 weeks till it rained again. I went thru another big puddle of water and it went off and hasn't come back on since. I did notice that if I turned the car off and turned it back on the light would go off. I think maybe the sensor might have been off a lil or something and going thru the water again righted whatever was wrong.
Old 05-08-2009 | 11:56 PM
1999chevy's Avatar
well i replaced the calapers in the front and rear so i dont thinks its that and idk know what the previous owner did to it cause he messed it up pretty bad if u know what i mean and i dont know if my third brake light works i will check but i dont think that would make the light come on would it?>
Old 05-09-2009 | 08:12 AM
02StanGT's Avatar
Yes it will.
Old 06-18-2009 | 09:25 PM
osduck5's Avatar
I recently purchased a 96 that had the ABS light energized. I found one of the wires that attaches to the sensor behind the front hub had a bad connection. I ohmed it out with a meter, sensor was good. Then I ohmed out the wire at the connection just inside the fender above the frame. There was no reading. Cleaned the connection at the sensor and light went out.
Old 06-19-2009 | 07:46 PM
shinwolf14's Avatar
make sure that your 3rd brake light works. mine came on and that light went out.
the funny thing was that i said i would replace it later because i was busy and about a week later, the light went off. it hasnt come back on since but the light is still broken
Old 06-20-2009 | 12:43 PM
libertyforall1776's Avatar
Get your ABS system diagnosed with a scan tool at a good shop (note that most store bought scan tools do NOT scan the ABS system), they can determine the failure which is most likely one of the wheel speed sensors (the test is if they don't all detect the same speed, as I recall), or the ABS motor pack (which I had go out on my '95 3.4L), which is an easy driveway replacement, just order it online as save some cash...
Old 06-21-2009 | 12:23 AM
camaro_burns_all's Avatar
VIP member
i agree with liberty, abs inop has a lot to do with faulty wheel speed sensors
zeusz28
09-27-2012 06:57 AM
camaro girl
12-09-2008 06:47 PM
thetal1
09-28-2008 02:21 AM
TEXASMAN1
04-23-2008 03:41 PM
bonedeth631
03-04-2008 07:47 PM
Quick Reply: ABS inop ??
