abs inop
Old 10-10-2008, 09:08 PM
camaro girl's Avatar
Default abs inop
i have a 97 rs and every so often my abs inop light comes on. nothing happens to my brakes or pedal they are still working. when i turn the car off and then start it again the light goes off then it will come back on a little later. does anyone know what could be the problem and how i can fix it? thank you
Old 10-10-2008, 09:09 PM
ledzeprokon6's Avatar
Default RE: abs inop
could be the computer unit. But just a heads up when the light is on ur abs will not work.
Old 10-10-2008, 09:12 PM
could i replace the computer unit? do you know how much that costs? thank you
Old 10-10-2008, 10:47 PM
02StanGT's Avatar
Could be a faulty wheel sensor. All the tires the same size all the way around?
Old 10-11-2008, 05:05 AM
Spartan66's Avatar
Is it like national ABS INOP month?
Old 10-11-2008, 07:11 AM
i have 2 bigger tires in the back they are the same size and the 12 in the front are the same size. why would that be a problem? thanks
Old 10-11-2008, 07:40 AM
did the problem begin occuring when you put new wheels on the car? And im not sure how much the computer unit is but they are up there.
Old 10-11-2008, 08:20 AM
it started shortly after the newer tires were put on. could that be why the light is coming on? thanks
Old 10-11-2008, 09:17 AM
Yes, the tires would have everything to do with it, if they're a different diameter. Under normal operation, the ABS system works by getting readings from the speed sensors at all 4 wheels. If it registers a different speed from one or more wheels, either while accelerating or braking, it will assume there is a loss of traction and activate the ABS/traction control. If you put on a pair of tires that are a different overall diameter from the other two, the ABS system is going to be constantly giving an off-reading to the computer. So, if that's what you did with the tires, your ABS system is confused. You have two (logical) options, get another pair of tires that match, or live with the fact that you don't have an operational ABS system any more.
Old 10-11-2008, 09:53 AM
02StanGT's Avatar
Exactly what I was getting at. That right there answers about 50% of the ABS Inop questions asked.
Quick Reply: abs inop
