98 V6 tach question
RE: 98 V6 tach question
This would normally be the case, but your car has DIS ignition with no distributor and 3 coil packs with no exposed leads. There is a white wire, pin C, on the large connector on the ignition control module (under the coil packs) which carries the tach signal, you can try tapping into it & see if the tach works.
