'98 PCV Valve Change - Help Please!
Old May 10, 2006 | 11:09 AM
Damien8086's Avatar
Default '98 PCV Valve Change - Help Please!
Hello, I am new here and have very limited mechanical experience. I have a 98 V6 camaro. I tried to change the PCV valve yesterday. I opened up the little diamond shaped plate with the two bolts on it. I pulled the spring out and then I pulled the PCV valve out, but I did not see any O ring as stated in the service manual. Is it possible that the O ring is missing? Should I order a new one and if so where would I do this at?
Also, when I pulled the valve out it was pretty tough to get out, but the new one dropped right in. Is that the correct procedure - to just drop the new valve in or is it supposed to somehow be screwed in? Is there a way to tell whether or not it is working correctly?
Thanks for your help.
Old May 10, 2006 | 06:30 PM
SickSickSick's Avatar
Default RE: '98 PCV Valve Change - Help Please!
You Have Let The O-Ring Fall Down In There. I Am Not Familar With The Model Your Dealing With ... I Just Know You Need To Fish It Out. Sick
Old May 10, 2006 | 08:59 PM
coolcat's Avatar
if you try fishing it out and you don't find anything, possibly the previous owner forgot to install one, you can find those at like an auto-zone, or checker auto parts.
If you don't have a parts stor near you try calling up a GM dealer and ordering one up.
Stix80
Jan 23, 2011 09:03 AM
LHill00Z28
Oct 3, 2009 12:36 AM
79camaro505
Feb 22, 2008 08:02 PM
libertyforall1776
Nov 10, 2007 03:04 PM
