96 camaro 3800 v6 missing
Old Jul 22, 2011 | 08:27 PM
hevymetalg's Avatar
I have the 98 v6 3800 series 2 camaro. I did the intake gaskets, and it's pretty easy. Just make sure you replace them with the aluminum gaskets. I have to get all of my plugs from the bottom except the two up front. I was going to say move the coils around and see if the missfire moves with the coil? Gd luck, and let me know if you need any guidance with the intake replacement. Oh the head gaskets on these engines are pretty tuff.
Old Jul 27, 2011 | 08:32 PM
BigCat2010's Avatar
I had a 96 3.8 that missed in #4 like mad with weak plugs and wires, gave it a tune up and it ran like a champ and then my evap system went nuts and broke... so I wound up replacing the whole thing. I feel your pain in that buy. I did the same thing...
Edit: I also had to replace the coils too, the #4 one was bad. I have 2 laying around with a fuel rail, if you're local you can just have it...
Old Aug 30, 2011 | 09:21 AM
fritcr's Avatar
Well the car seems to be running pretty good now except for the purge valve code. I still have not got to that. My main problem is the transmisison leaks a LOT of fluid out the shift shaft seal and I put 2 in and then paid someone to put one in. It is worse now after paying someone to fix it! Does anyone know what I do to stop the leak. It runs out everywhere all over the floor and even down the drain. I'm afraid we are going to ruin the transmission. Is there a sleave or something I'm missing?
Rob
Old Aug 30, 2011 | 05:24 PM
BigCat2010's Avatar
ooh, man that sounds like you might just need a whole new thread for that problem. lol.
Old Aug 31, 2011 | 12:14 AM
vanquishfist's Avatar
He did put one in Transmission Tech.
https://camaroforums.com/forum/trans...tomatic-59620/
th3fr4nchi5e
Sep 12, 2014 09:26 PM
SilverRunBootlegger
Mar 9, 2014 08:38 PM
98CamaroRS
Apr 2, 2010 05:04 PM
josh95camaro
Feb 18, 2010 02:22 PM
Kajura
82-92 V8 Tech
Dec 17, 2009 07:41 AM
