96 3.8 Shake Problem
ok so i replaced the plugs ( all the plugs looked exactly the same just some wear but nothing out of the ordinary, i dont have a camera that would take good pics) and wires but it still does it. I tested the Coils with an ohm meter and the coils are fine. i triple checked to make sure all the wires are in the right spots and on tight. I checked the tranny mounts and motor mounts and all are secure and good. It lightly shakes when idle, its when i get in to 2500 and higher it starts to get bad. Im trying to give you the best info i can cuase this is frustrating the hell out of me.
I had this shaking at the higher RPMs on my 95 3.4 -- the fix was replacing an electrically dead injector which was intermittently failing over the years evidenced by backfiring in the past.
