95 V6 3.4 Problem
Old Sep 26, 2005 | 06:17 AM
GarciaJose8's Avatar
Default 95 V6 3.4 Problem
I just replaced the heads on my car. Now my car has the Service Engine light on. When in idle, it goes up and down between 800 to 1200 rmp. And when i shift into first, the car acts if it was going to turn off. Any one has ideas on what i can do. Thanks
Old Sep 26, 2005 | 10:42 AM
02StanGT's Avatar
Default RE: 95 V6 3.4 Problem
Sounds like you might have a vacuum leak. Did you replace them or did a shop? If you replaced them did you make sure to use all new gaskets and clean all gasket surfaces? Make sure the intake manifold bolts are torqued the right amount as well.
Old Sep 26, 2005 | 05:20 PM
thirdgencamaro's Avatar
my old 2.8 did the same thing i replaced the alternator it idled fine try that
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
