95 3.4 Auto Problem!
Why did you buy a car with a bad transmission? Did you check the fluid level or change the fluid? If that was done, indications are that the transmission will need to be dismantled and rebuilt or replaced.
Possible problems:
Forward clutch assembly
Forward clutch accumulator
Input housing and shaft
Valve body
Low roller clutch
1-2 Accumulator assy
Low line pressure
2-4 Servo assembly
Stator roller clutch in TC not holding
Possible problems:
Valve body
Low roller clutch
Low line pressure
2-4 Servo assembly
rayistfaaku
01-21-2011 07:32 AM
