'95 3.4 to 3.8 upgrade, gotchas?
Old Apr 23, 2007 | 04:47 PM
libertyforall1776's Avatar
Default '95 3.4 to 3.8 upgrade, gotchas?
Hi all, I am considering upgrading my 1995 3.4 engine to a 3.8 liter -- are there any gotchas besides a new engine? i.e. any other parts which must also be upgrading like the PCM, etc.?
Any opinion on the worth of doing this upgrade? I have long thought that a little more power on the daily driver would be what is needed...
TIA!
Old Apr 23, 2007 | 05:30 PM
bluovlh8er's Avatar
Default RE: 3.4 to 3.8 upgrade, gotchas?
just a question, if you were going through the hassel of a 3.4 to a 3.8 then why not get a lt1 swap?
Old Apr 23, 2007 | 05:44 PM
Well, for a daily drive, I figured the 3.8 would make more sense since my other Camaro is an SS...
But hey, if you have some reasons behind your question that I should consider, I am all ears...
Old Apr 23, 2007 | 05:46 PM
badinfluenceRS's Avatar
they will both be nearly the same amount of work...
Old Apr 23, 2007 | 06:02 PM
bluovlh8er's Avatar
oooooooooooooooooooooooooooooooooo lol makes sence now. 3.8 is a good motor. for a daily driver.
Old Apr 23, 2007 | 10:49 PM
jhop16's Avatar
if you got a 3.4 for a daily driver and a SS as a other car... why bother putting a 3.8 in?
Old Apr 24, 2007 | 12:36 AM
Because the 3.4 always seems to be lacking a little bit extra needed passing power... I can't tell you how many times I've wanted just a little more... but not V8 more...
Old Apr 24, 2007 | 12:42 AM
3.8 series II is a rock solid engine...
If the 3.4 is in fine working order, I wouldn't touch it unless you do a V8 swap...
You could put some bolt-ons for it and gain a few ponies
Old Apr 24, 2007 | 11:40 AM
Raidenvaga's Avatar
Default RE: '95 3.4 to 3.8 upgrade, gotchas?
3.4 to an 3.8,,, Would you just have to change the cam rock piston fuel inj & tune, and get like 220-250 in the 3.4 ???
You don't have to swap engine
You just got to know how to work it , LOL
LOL
Old Apr 24, 2007 | 12:38 PM
you might get 200hp at the crank w/ a cam swap...I think 60-90hp gain is a bit drastic
