94 front brakes, manual trans
The code for the manual transmission? I do not think there is a option code for the manual trans since it is the Base transmission. I found a engine Suffix code for V6 and manual transmission MNA-MT. I have no idea what good that would do for you.
The all V6=manual shifts came with a T-5 transmission. The convertion process is not simple by any means. Your computer system controls the shifting in your automatic. If you just disconnect it you will have problems. It is possible but it will be a fair amount of work and you are going to need a lot of parts.
The calipers change in 98 but I do not think there is any differents V6-V8
