94 camaro v6 3.4 vibration problem
Old Jan 27, 2010 | 01:08 AM
  #21
Thunder66's Avatar
yea me too. yea automatic, checked out bottom side today and all looked good and did some checks with it on the lift and in gear sounds like to me that its somthing making motor run rough and its making the exhuast vibrate making the y pipe make a hollow vibrating noise
Old Jan 27, 2010 | 05:59 AM
  #22
knock sensor?
Old Jan 27, 2010 | 08:29 PM
  #23
Thunder66's Avatar
is this motor 3.4 v6 internaly balanced or external?
Old Jan 27, 2010 | 08:57 PM
  #24
find your knock sensor (could be two on your car)and make sure it or they are pluged in. if they are plugged in and look good then unplug em one at a time and see if it makes a difference. if no difference in the way it runs then the sensor is bad or the wire is bad or the connection is bad. sensor or sensors should be on the side of the block below the exhaust manifold.
dingurt
Jan 13, 2012 07:26 PM
shinwolf14
Jul 18, 2009 09:34 PM
DAVIDP2000
Apr 9, 2009 08:51 PM
gadmhahn
70-81 V8 Tech
Apr 5, 2009 09:51 PM
Iroc
Aug 11, 2005 09:40 PM
