94 3.4L problems
Old Jun 28, 2008 | 10:23 PM
jap901's Avatar
Default 94 3.4L problems
Hello i just traded for a 94 3.4L camaro knowing it had problems b4 hand it had been seating fo rsome time and i ran what little old gasin it out and added 5gal on new gas and a can of sea foam injector cleaner also there is no cat on the car.It cranks and runs fine at ideal when cold but if the car gets under a load like up a big hill or you realy gas on itsounds like it cutting out runs realy rough and once the enigne id warm up it doesn't want to crank unless you give it a little gas. there is no ses light on and i put a paper clip on A and B to pull codes but the ses light does not blink not even code 12 like it should. the ses light is good because it gomes on like it should just b4 starting the engine.
Please let me know if you have any ideas
thanks Jim
Old Jun 30, 2008 | 06:54 PM
jap901's Avatar
Default RE: 94 3.4L problems
I see everone else is confussed on this problem also, but here is a update. I checked the TPS with a meter and it showed 4.56v with thottle closed and voltage drop as it was opened to full throttle so i replaced the tps and it is doing the same thing but voltage is 4.44 with throttle closed.
Also on the data log link where you short out pins A and B doesn't one of them post to have 12V I am not getting any volts for A or B but i belive a is ground.
Old Jul 2, 2008 | 08:44 PM
jap901's Avatar
It seems to be some what better but it still studders when you gas on it, so i though i try a computer out of my friends junk 94 firebird with a 3.4L and was not sure if it would work because of the VATS but it ran the car but doing the same thing and still not getting code 12 when pulling code of the computer getting nothing at all.
Old Jul 7, 2008 | 04:26 PM
jap901's Avatar
Found the problem and here is the update. The TPS is working right i was measuring the wrong two wires. I got a friend that has a juck 94 firebird so he let me try diff parts of it.
things I changed that did not make a diff is
spark plugs, plug wires, fuel filter, TPS all these parts where bought New.
The problem was the coil packs not sure which one because i just replaced them all from the donner car.
Old Jul 7, 2008 | 04:37 PM
There you go! I figured if we left you alone long enough, you would figure it out. Need help with anything else?
Old Jul 7, 2008 | 06:17 PM
jap901's Avatar
LOL! Thats funny. My question must have been[sm=ts.gif][sm=joke.gif]I have had spark plugs do what I was having a problem with but never a coil pack. and as for the computer not giving me any codes not even the 12 code I read that a lot of 94s had a problem with this.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
