94 3.4 v6 Camaro NO SPARK URGENT!!!!!
Old Jul 28, 2015 | 07:58 AM
Cjwelsh's Avatar
Okay so I connected a light between the power and ground terminals of harness to icm. Nothing. Pin b to ground.. Nothing. hit it again with volt meter, 12v on grd ans 4 on hot. So ignition circuit 239? The issue here is clearly the amount of power flowing to my module?
Old Jul 28, 2015 | 09:42 AM
trace it back to the plugin and look for bad connection
Old Jul 28, 2015 | 01:53 PM
Cjwelsh's Avatar
Chased the wire down to behind the block, found nothing. If I jump this module while cranking would it hurt my vehicle?
I am stumped.
Old Jul 28, 2015 | 01:55 PM
Cjwelsh's Avatar
I am stumped.
Same voltage before connectors. The manual calls for a pink wire 12v. I've got a yellow wire with 4 and a steady four through the harness. Someone please tell me this wires life and its journey through the harness
Old Jul 28, 2015 | 04:33 PM
looks like your on the wrong harness, yellow goes to the 3x cps. do not put voltage to the yellow wire it could fry the ecm and icm.
Old Jul 28, 2015 | 04:35 PM
look it up in the 94 book to make sure its the same, what i posted is for a 93, i think its the same but dont know for sure
Old Jul 28, 2015 | 08:37 PM
Cjwelsh's Avatar
Well i know the manual calls for a pink wire. However, this wire is the 2 prong hot wire attached to the ICM on the top side. Im wondering if the previous owner replaced it? I chase the yellow wire and get nothing. The connector with the 3x signal is a 3 prong. If im not mistaken. And inly gives me a reading while i attempt to crank the ngine
Old Jul 28, 2015 | 08:59 PM
Cjwelsh's Avatar
However, the wire I'm probing only reads when key is on position. I what does the 10 way fwd connector look like maybe its losing it there. I know that the fuse reads 11.9 with the key one through fuse.. Just losing it before it reaches the icm
Old Jul 28, 2015 | 11:17 PM
ill look to see if i can find it. and it worked before so its something thats different. the wiring harness to the engine is the one from the car the engine is going in right? the 94 and 95 have different ecm and a few other things so you will want to keep as much as you can original to the car.
Old Jul 29, 2015 | 02:21 PM
  #20
there should be a plugin back toward the transmission, it looks like thats where its at, at least in my book.
