93 Camaro weird hesitation when accelerating.
So my 93 camaro v6 hesitates when I get on the gas. I thought it was my o2 sensors but I changed them and the same thing occurred. I have one sparkplug that is frozen into my block, but all the rest are new. Could that be causing the hesitation? There is also a knock sometimes that follows the hesitation at higher rpms.
Here is what was recently done:
New spark plugs (except for the one frozen in the block)
New plug wires
Oil change
Trans fluid change
Serpentine belt
radiator flushed
new 180* thermostat
power steering lines
radiator hoses changed
Aftermarket stuff:
1 piece aluminum driveshaft from a 99 Camaro SS.
Rear end from a 99 Camaro SS (I wanted 4 wheel disc brakes and 3.42 gears)
Ram-air intake.
Heres a vid of the problem.
http://www.youtube.com/watch?v=14rdIIAW_pM
New plug wires
Oil change
Trans fluid change
Serpentine belt
radiator flushed
new 180* thermostat
Aftermarket stuff:
Ram-air intake.
my '93 has the same problem, although im not sure why. i changed the fuel filter and that seems to help, but my girl has a '94 firebird 3.4 thats an automatic and mines a stick and it seems to have more power by far and mine still hesitates... it'd be great to know whats causing it...
The spark plug was stuck in the block when I bought the car. It is rusted around the part where you are supposed to put a socket. How would I go about checking the coils?
Yeah I know, and its on the left side of the motor in the middle, so its in the most cramped spot ever. I'll probably end up getting msd packs and wires. I thought the hesitation might be caused by a clogged catalytic converter too because the car has almost 200k.
get a spark plug socket with bolt type end the use an open end wrench on it to unfreeze it lol good luck bud.
I would, but its impossible to get to. See image:
![Name: 34engine.jpg
Size: 38.9 KB](https://camaroforums.com/forum/attachments/93-02-v6-tech-14/35733d1501323733-93-camaro-weird-hesitation-when-accelerating-34engine.jpg)
Its the plug right behind that sensor, I tried removing it but broke the head off one of the bolts. Its got rust all the way around where the socket should go.
