93' 3.4L v6 3400 to 3500 Top Engine swap?
Roger that now I'm looking to buy two engines, a 3.4L and a 3400, I can get both for about $550 I think, my buddy has a shop/salvage yard, been talking him lower on 3.4L so if I get two at once he might ne nice, then I could have alot of spare parts!
Get a v8 6-speed rear end from a 93-02 f-body, it'll have 3.42 gears and disk brakes. The wiring plug will be the same and all you'll have to do it "T" your single brake line coming off the chassis to fit the two brake lines on your new rear end. Or you can use the brake lines and t block off the old rear end and plug them into the disk brakes on the new rear end. Everything else bolts up as factory. Happy swapping
