88 2.8 fuel pressure question
Old Jun 6, 2006 | 06:45 AM
sewerrat's Avatar
Default 88 2.8 fuel pressure question
I'm working on an 88 Camaro V-6 2.8. Can anyone tell me what the correct fuel pressure should be at idle and where is the test port located?
Thanks.
Old Jun 7, 2006 | 10:45 PM
Default RE: 88 2.8 fuel pressure question
Is the car carbed or injected? If it uses MPFI, the test fitting is on the fuel rail. Key on & engine stopped pressure should be between 34-47 PSI. With the engine idling the pressure should drop 3-10 PSI. If it is carbed, you will nedd a gauge with a T fitting and insert it between the fuel line & carb, pressure should be 5-8 PSI.
Old Jun 8, 2006 | 04:09 AM
sewerrat's Avatar
Thanks z28pete, it is MPFI. I did find the test port hidden behind the upper plenum. A friend gave me this car which hasn't run for 3 yrs. I found the intank fuel pump stuffed with crud from the tank. I'm hoping I can clean the tank out, replace the pump and strainer. Replace the fuel filter and pray nothing went past that into the injectors. Sometimes FREE isn't always best.
Mike
Old Jun 15, 2006 | 12:40 AM
lukiez76's Avatar
When yyou replace the fuel pump dubble check your fillter and dont let any scare you you only have to remove the swing arm suspension then all heat shields drop tank u shoould be fine but if you dont get it runing there are somtimes fuses and a relay in the engine compartment I can give you more details if you want them.
Old Jun 15, 2006 | 06:53 AM
sewerrat's Avatar
Thanks lukiez, I actually had to remove rear shocks and sway bar to get the rear end to drop down far enough. My worst case scenario came true. I pulled the injectors and found 4 out of 6 plugged at the filter. If you get a chance I do need the location and description of the fuel pump relay for the 88 Camaro. My Haynes manual doesn't show the location. Thanks
royco95
Aug 2, 2015 10:25 AM
pwcfire
Apr 8, 2012 07:57 AM
gagger84
Sep 2, 2011 05:29 PM
auto
Jul 19, 2011 09:33 PM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
