84 2.8 swap
Old Sep 22, 2006 | 05:20 PM
Frost's Avatar
Default 84 2.8 swap
i have an 84 camaro thats got a burned piston bearing so im going to have to pull the engine, but i figured wile im pulling it i mine as well just put a new engine in or rebuild my old one. i just want to know if i could put in a 305 without pulling the trans or even a bigger v6.
Old Sep 22, 2006 | 05:37 PM
SickSickSick's Avatar
Default RE: 84 2.8 swap
for a V-8 if it's a standard you can switch out the bellhousing ... if it's auto you will have to change out trannys. for a V-6 your tranny will fit. Sick
Old Sep 23, 2006 | 12:12 PM
AlfredB18's Avatar
A 3.4L v6 would do the job acceptably.
Old Sep 23, 2006 | 04:13 PM
Frost's Avatar
i found a 3.8L 3800 Series III engine thats a v6, would this fit good into my 1984 camaro?
http://www.truckstv.com/crate/crate.html#24
or should i stick with the 3.4 V-6
Old Sep 24, 2006 | 12:05 PM
AlfredB18's Avatar
ORIGINAL: Frost
That's the supercharged v6 ONLY for FWD applications. Now, maybe the 3rd Gens have enough room to make that swap possilbe, but if you haven't budgeted the time and labor to wire that bad boy up....go with a 3.4L.
At least you can carb a 3.4L if you are on a budget.
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
