4.3 swap
Old Nov 11, 2011 | 09:28 AM
jasonh3609's Avatar
Default 4.3 swap
How hard would it be and what else would I need to put a 4.3 in a 2001 besides the engine and ecu
Old Nov 11, 2011 | 11:41 AM
That would depend. Do you have access to a machine shop, plasma cutter and a mig welder? And do you have the fabrication skills to use the before mentioned equipment? If so it is not a hard project. If not then you going to need a wheel barrel full of money to have parts made. Stock manifold will not clear custom headers alone would close to $1000.
3800 is a better engine and can be bought cheaper then a 4.3 anyway.
Old Nov 12, 2011 | 01:52 AM
You'll also have to replace the transmission, as the 4.3 has the same bellhousing pattern as a V8. The 4.3 won't bolt to your trans.
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
