3x00 top end swap question
Old Jul 4, 2012 | 02:56 PM
305_camaro's Avatar
March 2012 Ride of the Month
Default 3x00 top end swap question
So I am intending on doing the 3100 top end swap and all the articles I read about it saythe engine must be removed. My question is does the engine really need to be removed?I have changed the head gaskets on this previously and I never pulled the engine then. If it is a direct bolt on then why remove it? If I hear that it doesn't need taken out I will probably tackle the swap soon.
Old Jul 4, 2012 | 05:08 PM
Chaotic94's Avatar
September 2011 ROTM
Your best bet is to at least lower the engine by un bolting the k member and shock towers.
Old Jul 4, 2012 | 05:09 PM
Chaotic94's Avatar
September 2011 ROTM
And depending on which top end swap you do, you may need to replace your pistons.
Old Jul 4, 2012 | 06:18 PM
BasicConcepts's Avatar
Technical User
the 3100 swap is direct no need to pull the engine. and i think its only the 3500 swap that requires new pistons.
Old Jul 5, 2012 | 12:51 AM
305_camaro's Avatar
THank you! this weekend i very may well be doing this swap!!! It is direct bolt on and no pistons need changed...hello bolt on 30rwhp and 25rwtq!
Old Jul 5, 2012 | 01:25 AM
Chaotic94's Avatar
September 2011 ROTM
It's the 3400 that requires piston swap. The 3500 swap doesn't require piston swap but runs something like 11/1 compression...
Old Jul 5, 2012 | 02:33 PM
305_camaro's Avatar
Last question do I have to run headers??
Old Jul 6, 2012 | 12:45 AM
Chaotic94's Avatar
September 2011 ROTM
Not sure but I believe you can run which ever stock manifolds that go to the heads you choose. Or grab headers that woul originally go to a 3.4 Camaro/Firebird. There's a really good thread about the 3X00 swap on fullthrottlev6.com it should be in the 60degree section. It's a sticky I believe.
Old Jul 6, 2012 | 01:03 AM
Chaotic94's Avatar
September 2011 ROTM
Here ya go man!
Aluminum Head Swap Info (with pics))
Good luck and let us know if you have any more questions. 99% of the info you need is in that thread tho.
Old Jul 6, 2012 | 03:17 AM
305_camaro's Avatar
Originally Posted by Chaotic94
Here ya go man!
Thanks bro! This has actually been bookmarked on my toolbar for a couple weeks. He said he got headers because they fit but i think when he said something about them fitting i think he was comparing the rksport and pacesetter brands...kinda jealous you got Socoms set lol
