3800 Valve series 2 adjustment?
Old Jul 24, 2010 | 01:15 PM
crankyyank's Avatar
Default 3800 Valve series 2 adjustment?
I have a 96 3800 Series 2 that I had to have the heads milled on I am putting the heads back on and I cant find if the valves have an adjustment or not.
I have read 10 different things....They look like they DO NOT. They have a roller setup that looks like positive stop to me. This is NOT a 3.4 or 5.7 that has a stamped rocker.
CAN SOMEONE ANSWER THIS FOR ME
THANKS
Old Jul 24, 2010 | 01:34 PM
dont know but would like to see a picture. if the rockers are on a shaft then there not adjustable. if you have rockers with a bolt holding each of them down then thats were you adjust em. most roller rockers call for 1/2 turn down for hydraulic lifters. arrr the lifters solid or hydraulic.
Old Jul 24, 2010 | 02:53 PM
No adjustment. Your machine shop should know the max amount they can machine off. They should not have gone beyond that. If they did go too far you may be able to shim up the rockers.
Old Jul 24, 2010 | 03:58 PM
crankyyank's Avatar
Ok
Got it, i didnt think they had an adjustment.
jwolfe2kx
Jan 30, 2015 06:43 AM
Sophm
Oct 22, 2013 08:39 PM
shadypup99
Apr 8, 2012 09:17 PM
BlitzKrieg
82-92 V8 Tech
Mar 20, 2007 11:28 PM
