3800 motor change
Old May 15, 2011 | 12:57 PM
CamaroCam's Avatar
yes that intake has the curve on it. so when i change the intake i should still do top and bottom?
Old May 15, 2011 | 02:05 PM
Either way the bottom is the way to go. Email sent,,,,,
Old May 15, 2011 | 04:24 PM
Massey's Avatar
I think he ment the intake Gorn. I would do them both as a set. I think the older ones are the same but just use your lower just to be safe.
Massey
Old May 15, 2011 | 06:36 PM
wildcatk23's Avatar
If your gonna switch intakes and gaskets use no cheap alternatives or youll be opening that engine again as soon as a hot day rolls around.
Old May 15, 2011 | 11:02 PM
CamaroCam's Avatar
I already put new gaskets in the other motor.. can i just put them on the other intake no problem? thanks for the info GORN
Old May 16, 2011 | 04:25 AM
Massey's Avatar
NO DONT DO IT!!! Once you torque a gasket down and apply heat to it, it will seal itself to the engine. Reusing said gasket is asking for trouble. It will fail and with that it could take out the engine as well.
Oil pan and valve cover gaskets are not as sensitive and can be reused if not damaged. These do not hold any pressure they just keep the oil inside the engine.
Massey
Old May 16, 2011 | 05:43 AM
CamaroCam's Avatar
the motor has been sitting in a garage....its still not ok? I havent ran it or tried to start it because i didnt have the tools to change the motor then so i sat the motor to the side..... but i need to get new intake gaskets?
Old May 17, 2011 | 02:34 PM
CamaroCam's Avatar
starting the motor change today ill throw some pics up
Old May 17, 2011 | 05:47 PM
wildcatk23's Avatar
Good luck. Make sure u dont get your harness wires caught in behind your motor. We done that and had to take the motor loose again which was a huge pain.
Old Jun 25, 2011 | 02:12 AM
  #20
CamaroCam's Avatar
So the motor and trans are now changed but tranny fluid is spilling everywhere and car wont shift into any gears?
