3.8 cylinder 6 misfire
Old Feb 21, 2018 | 10:28 AM
859camaro's Avatar
Default 3.8 cylinder 6 misfire
Just had all o2 sensors replaced when my headers were installed. Installed new 8.5mm wires 90 degree boots and all new plugs. Ran great and started stuttering a little. Ran code and its a cylinder 6 misfire. I know the front 2 coils were just replaced 300 miles ago. Would coil 3 be my possible issue?
Old Feb 21, 2018 | 01:34 PM
A common mistake to make is assuming a new part can not be defective. I spent a good part of my career working on cars with less than 500 miles on them and they and most of the time it came back to defective parts.
If you think it may be a coil then just switch the coils and see if the error follows. Don't be surprised if its a cracked plug.
Old Feb 21, 2018 | 09:20 PM
for future reference, many headers have a coating on the inside that when burned off can mess the 02 sensors up. best to run the old ones for a few days then install new.
Old Feb 22, 2018 | 01:58 PM
859camaro's Avatar
Thats the bad part the old ones were fused in the manifold. Had 2 shops try so instead of dropping money on manifolders headers were cheaper. Luckily the way its repositioned i can get to it easier
Old Mar 2, 2018 | 10:01 PM
859camaro's Avatar
Ok so i replaced coil wires and plugs .still a constant misfire. My buddy said his ecm was going out and was causing his .ive also heard the icm... And advice cause i love my car but this has been constant for months to where my dd is useless
Old Mar 2, 2018 | 11:49 PM
Is it still cylinder 6 code? Have you tried swapping coils and fuel injector to see if the error follows anything?
Old Mar 3, 2018 | 02:08 AM
859camaro's Avatar
No idea how to do an injector but ill swap coils today and try
Old Mar 3, 2018 | 05:52 AM
if you havent yet go here and download the factory service/shop manual. http://www.mediafire.com/?40mfgeoe4ctti 2000 svcman will be same as yours.
Old Mar 7, 2018 | 06:46 PM
859camaro's Avatar
Anyone know if i can get a replacement injector pigtail? Or the part number. Figure out the issue and its in the plug
Old Mar 8, 2018 | 07:06 AM
Rock Auto should have them.
nwolf10
Sep 29, 2008 05:23 PM
gregcamaro
Apr 21, 2008 10:38 AM
Spartan66
Apr 12, 2008 07:32 PM
JKEpps
Jun 25, 2007 12:13 PM
powers28ss
Oct 3, 2006 12:13 PM
