3.4l missfire?
Old 11-19-2011 | 11:37 AM
Originally Posted by IdriveDSM08
how am i supposed to check for codes on a obdI? and does the cel have to be on when the code is being pulled cause mine is only on for short periods of time.
Ideally you should use a OBDI scanner, but you can also flash the codes. You can search the forum for the procedure to flash the codes.
Old 11-20-2011 | 05:29 PM
IdriveDSM08's Avatar
can you flash codes on the 94? hmm.. well will this scanner work to get the codes or does it need to be a fancy one?
Old 11-20-2011 | 06:01 PM
slick's camaro's Avatar
problem 1. don't kno I have the same plug tuck away. its affecting anything I kno of..
problem 2. that is your coolant temp sensors on the head behind the coil packs. replace it.
problem 3. that's your fuel return line...
problem 4. your fuel return line in problem 3 goes there. purge.
problem 5. yes you can. but you can get from a link yard for $1.00.
did I miss anything...
Old 11-20-2011 | 07:58 PM
nope you had got it all but i had already fixed it though lol thanks though but if you know anything about pulling codes from a 94 camaro i could use it.
Old 11-20-2011 | 08:21 PM
you should be able to flash codes on a 94 with the scanner pic above since it is OBDI. now the 95 yr. is the pita because of the conversion that year.
Old 11-23-2011 | 02:50 AM
whats normal temp for these motors? mine never reads but just above 160
Old 11-23-2011 | 06:36 AM
195. is when the thermostat open. fans cut on around 200-210.
SpecterGT260
02-16-2013 01:09 PM
deadfast142
03-31-2010 06:28 PM
liaa777
10-26-2009 12:41 AM
Jay from Holland
08-06-2008 02:42 PM
JerseyBoy9696
01-31-2008 08:15 PM
Quick Reply: 3.4l missfire?
