3.4L, coolant disappearing
Old Jun 2, 2010 | 05:12 PM
  #31
grover's Avatar
Well, STILL didn't work. The angle of the dangle just didn't quite fit. Before I broke out the hammer and anvil to make it fit, I gave it a shot with the crow's foot 13mm that came with the kit and allowed a slightly less impossible angle and... WOOHOO!!! broke the motherf$#@$3r loose!!!! Managed to work it the rest of the way out with an angled ratchet wrench from an extremely uncomfortable position balanced with my knees on the radiator, chest on a 2x4 spread across the engine bay and forehead on the windshield. Did I mention a thunderstorm rolled in and it started raining right as I broke it loose?
Now, I'm all set to shove this bolt up the bunghole of whatever engineer designed that part of the engine bay. I'm an engineer myself- there's no excuse for bad design like this, not for a bolt that requires such force to break loose.
Old Jun 2, 2010 | 06:54 PM
  #32
grover's Avatar
Amazing how such a tiny bit of damage can kill an engine
Old Jun 2, 2010 | 08:51 PM
  #33
osduck5's Avatar
^5! Glad you got it out.
Old Jun 6, 2010 | 07:27 PM
  #34
grover's Avatar
I'm well on my way towards reassembly now. I'm rather worried about valve lash. What, exactly, should I be checking for with valve lash? Being able to move the lifter rod up and down, or being able to rock the rocker arm back and force? I *thought* I had it perfect, but then put the lower exhaust manifold on and noticed I still have some movement in some of the rocker arms, and the rocker arm nuts aren't as even as I remembered them being when I took them off...
What's the best way to get the old cork gasket out of the valve covers?
Edit: nevermind on both counts. If the lash is wrong, too late to worry about it now! We got the old cork gasket out with a combination of chisel and dremel with a floppy sanding head.
CountTripula
Mar 20, 2022 05:57 AM
jagatorz
Feb 24, 2012 09:58 PM
jagatorz
Feb 11, 2012 05:47 PM
bbjk08
Oct 13, 2011 03:30 PM
aleksandr
Jun 15, 2008 06:31 AM
