3.4 V6 Ground Wire
Old Sep 12, 2005 | 09:12 AM
vhodgesosu's Avatar
Default 3.4 V6 Ground Wire
This is my first post. I recently replaced my head gaskets on my 1995 3.4L Camaro and I have a ground wire that I have no idea where it goes. Some how i forgot to label it when I took it off. Anyways, I know that it bolts to the frame below the Air Intake and then bolts to the engine somewhere. It is a braided copper wire with a clamp attached to it. I think the clamp holds the wiring harness. I know it goes on the drivers side and somewhere on the lower half of the engine. If anyone could take a glance at their 3.4l and see if they could find out where it attaches that would be greatly appreciated.
Thanks.
Old Sep 12, 2005 | 08:08 PM
85Camarodude's Avatar
Default RE: 3.4 V6 Ground Wire
if nobody replies u can always go to a salvage yard and check one out there, might be easier if u can physically see the connection urself as well
Old Sep 12, 2005 | 10:14 PM
Connect it to any convenient spot on the engine block, just make it good an tight. It really does not matter where on the engine it is connected.
Old Sep 13, 2005 | 02:17 AM
vhodgesosu's Avatar
I guess that is what I am going to have to do. I just don't know what the purpose of the wire is. I will give it a try, it is better than not having it on at all.
Old Sep 13, 2005 | 09:51 AM
The purpose of the wire is to provide a good electrical connection between the engine and the rest of the car. The battery negative connects to the engine and has to be carried to the rest of the car in order for lights, radio, etc.. to work properly.
Dan Taylor
Jun 10, 2012 07:00 AM
numskull223
Jan 25, 2012 04:25 PM
emptysmile005
Sep 26, 2011 11:56 AM
9434V6
Aug 19, 2011 08:52 AM
twankieman91
Dec 19, 2007 06:46 AM
